DDakic
Pozdrav,
pojavila mi se ova greška P0172 i P0170 koja se pojavljuje od ugradnje plina(ali nikada nije palila lampicu)
Ovo sam iščitao:
Freeze frame report generated by Torque for Android
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 16,078 %
Engine Coolant Temperature = 26 °C
Fuel Trim Bank 1 Short Term = -24,219 %
Fuel Trim Bank 1 Long Term = 0,781 %
Intake Manifold Pressure = 11,893 psi
Engine RPM = 1.586 rpm
Speed (OBD) = 20 km/h
Mode $06 report generated by Torque for Android
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0,53V Min: 0,53V
Test result value: 0,53V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0,57V Min: 0,57V
Test result value: 0,57V
PASS
MID:$01 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 1
Max: 65,535V Min: 0V
Test result value: 0,025V
PASS
MID:$01 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 1
Test result value: 1,275V
PASS
MID:$01 TID:$41
Max: 0,698V Min: 0V
Test result value: 0,015V
PASS
MID:$01 TID:$a1
Test incomplete or dependant test failed
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0,695V Min: 0,695V
Test result value: 0,695V
PASS
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Test result value: 0,07V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Test result value: 0,7V
PASS
MID:$02 TID:$41
Max: 0,698V Min: 0V
Test result value: 0,005V
PASS
MID:$21 TID:$81
- Catalyst Monitor Bank 1
Ako ima netko da mi ovo malo rastumači...da li je sve ok ili ne..poništio sam grešku te se još jedamput pojavila, nakon toga je za sada mirno...
Imam plin u autu ako nešto znači...
Pozz,
jutros opet..ovo sam iščitao sa freez-a..nadam se da netko možda može prepoznati nešto iz ovoga..
Engine Load = 10,588 %
Engine Coolant Temperature = 17 °C
Fuel Trim Bank 1 Long Term = -2,344 %
Intake Manifold Pressure = 5,511 psi
Engine RPM = 2.386 rpm
Speed (OBD) = 17 km/h
Ne znam otkud da krenem čistiti...
Ovo sam iščitao:
Test report:
MID:$01 TID:$01
PASS
MID:$01 TID:$02
PASS
MID:$01 TID:$07
PASS
MID:$01 TID:$08
PASS
MID:$01 TID:$41
Max: 0,698V Min: 0V
PASS
MID:$01 TID:$a1
MID:$02 TID:$01
PASS
MID:$02 TID:$02
PASS
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$41
Max: 0,698V Min: 0V
PASS
MID:$21 TID:$81
Pozz,
