Neobavezni razgovori (stara tema)
Status
Zmix
Re: Neobavezni razgovori
Skvi... pardon!
Mirda šes'et devet, znaš li nekog dobrog očnog lekara da odemo zajedno?
Tebi se mute brojevi a meni se tope boje na monitoru? ROFL
Hahahaha,ma meni ti je to sad od pive..doša izvana maloprije ;)
Inaće ti je meni s očima sve Ok ROFLROFLROFL
Kakva sad rikša ??? :wtf::a to ghorvat traži rikšu..
ghorvat
Re: saxo problemi s ler gasom
TU9 /K 70.0 x 62.0 mm 954 cm3 45 ch Carbu simple corps
TU9 M/Z 70.0 x 62.0 mm 954 cm3 50 ch Injection, catalyseur
TU1 /K 72.0 x 69.0 mm 1124 cm3 55 ch Carbu simple corps
TU1 F2/K 72.0 x 69.0 mm 1124 cm3 60 ch Carbu simple corps
TU1 M/Z 72.0 x 69.0 mm 1124 cm3 60 ch Injection, catalyseur
TU1 JP 72.0 x 69.0 mm 1124 cm3 60 ch Injection, catalyseur
TU2 4A 75.0 x 73.2 mm 1294 cm3 95 ch 2 carbus double corps
TU2 4A/K 75.0 x 73.2 mm 1294 cm3 103 ch 2 carbus double corps
TU2 J2/Z 75.0 x 73.2 mm 1294 cm3 100 ch Injection, catalyseur
TU3 A 75.0 x 77.0 mm 1360 cm3 65 ch Carbu simple corps
TU3 A/K 75.0 x 77.0 mm 1360 cm3 70 ch Carbu simple corps
TU3 F2/K 75.0 x 77.0 mm 1360 cm3 75 ch Carbu double corps
TU3 M/Z 75.0 x 77.0 mm 1360 cm3 75 ch Injection, catalyseur
TU3 JP 75.0 x 77.0 mm 1360 cm3 75 ch Injection, catalyseur
TU3 A (autre) 75.0 x 77.0 mm 1360 cm3 75 ch Injection, catalyseur
TU3 S 75.0 x 77.0 mm 1360 cm3 85 ch Carbu double corps
ET3 J4 75.0 x 77.0 mm 1360 cm3 90 ch Injection, catalyseur
TU3 FJ2/Z 75.0 x 77.0 mm 1360 cm3 95 ch Injection, catalyseur
TU3 FJ2/K 75.0 x 77.0 mm 1360 cm3 100 ch Injection
TU5 JP 78.5 x 82.0 mm 1587 cm3 90 ch Injection, catalyseur
TU5 J2/L3 78.5 x 82.0 mm 1587 cm3 105 ch Injection, catalyseur
TU5 JP4 78.5 x 82.0 mm 1587 cm3 110 ch 16 soupapes, catalyseur
TU5 J4 78.5 x 82.0 mm 1587 cm3 120 ch 16 soupapes, catalyseur
TU5 JP4 S 78.5 x 82.0 mm 1587 cm3 125 ch 16 soupapes,catalyseur
TUD3 75.0 x 77.0 mm 1360 cm3 53 ch Diesel
TUD5 77.0 x 82.0 mm 1527 cm3 58 ch Diesel, catalyseur
Zmix
Kada bih ja ovo napravio, umro bih u momentu!
Tema je promašena jer koliko vidim ova đinđa ima problem sa mehanikom a ne sa ler gasom. :D
Re: Èlanovi
A zar niko nije primitia da nam je "škafetin" obnovia garažu ?? Sram vas bilo sve skupa:D:D
I vi ostali linjivci bi se tribali ugledat na dotičnog člana :cool:
Tanaja
"Max. utegnut za vozit"
Re: Èlanovi
Èeka ga je prvo oprat. :)
Èini mi se da je Lageros reka da ima novi C5... Ma ne bi mu on sliku stavija ni za jedne pare. :D Da mi ostali možemo slinit ka ljudi. :cool:
Tanaja
Èovik pita za ler gas, a vi njemu pravite špagu u temi. :) Može vas biti jedino stid i sramota. :D
Re: Èlanovi
E,lin je i škrt..ne da ima c5..nego ima i berlinga i nekog fikusa :D:D:D..al nebi taj sliku stavija,a-aaa
A ća nam skafetin ima sad dvi garaže ?? Oli ima dvi crvene piksare ?
Re: Èlanovi
Ovim putem pozivamo svekoliko članstvo da ispuni svoje garaže slikama kako i priliči...da nebi bilo nismo znali ROFLROFLROFL
Tanaja
Re: Èlanovi
I pod obavezno triba povečati kapacitet slika. S tri na minimalno deset po kategoriji. tako da motor i kotače mogu snimit iz deset uglova.
dobro, zaj3bavan se, al isto bi moglo više slika stati.
Re: Èlanovi
Slažem se !!
I još nešta..da se upisuje lokacija oklen je netko..a ne da pomoću "vidovitog Milana" pogađamo ko je odakle...npr. neki pita za savjet,a ti mu lipo veliš ima toga na "reljiću" a on pita jel to u Splitu... :D:D:D
Nije teško napisat oklen si..mislim,pa nisu to neki intimni podaci
zoran37
Skvi... pardon!
Imam ja dobrog psihijatra, moj ludi doktor ak kome treba mogu vas preporučit, ićete preko reda i ne treba narudžba.
skafetin
Re: Èlanovi
Evooo mene a svaka vam čast na dobrim ričima ma jučer san se zaj pa san stavija isto auto u dvi garaže tako da ne mislite da iman dva ista;)
Re: Èlanovi
Ma šta te briga :D Kad neće ovi drugi stavit nijednu,što ti nebi ima dvi ? ROFLROFL
Status
