C4 Aircross
Sale
cfh
Following the official announcement made with the use of a teaser image, the French carmaker Citroen has just added another model to the lineup. Called the C4 Aircross, and basically uses the same formula as the C3 Aircross, but in a much more interesting package.
The news is that it doesn’t look one bit like a jacked up hatchback, instead the French carmaker keeping true to its design prowess with a unique shape and rugged.... brown looks. With so many interesting products currently on offer, it’s such a shame that they are drawing the short stick in European car sales these days.
Getting back to the C4 Aircross, this crossover will be introduced in the first half of next year with a choice of either two- or four-wheel drive. The AWD version also brings selectable drive modes: 2WD for fuel efficiency, 4WD that automatically distributes the torque between the front and rear axles, or lock mode, which increases the torque distribution to the rear wheels for more grip under severe conditions.
The engine choices include center around two very efficient diesels, Citroen’s HDi 110, which is a 1.6-liter and is mated to a 6-speed manual gearbox, or the HDi 150, also available with 2WD and 4WD with a 6-speed manual gearbox. If you want a petrol engine, the only choice is a atmospheric 1.6 that only comes with a five-speed gearbox.
So, let’s sum it all up: the LED are vertical, the front end design is as futuristic and as complicated as a scene from Transformers, and it should also be very economical.
Tanaja
"Max. utegnut za vozit"
Da bar hoce ovako iznenada izaci C4 Coupe
Ne virujen, C4 kupe je jedinstven i neponovljiv isto ka i C2.
Da se razumimo novi C4 izgleda fantastično, ali da je napravljena revolucija u dizajnu u kompaktnoj klasi ka i sa strain C4, e to nije.
valjda ce izbacit koji ili bar ds3 by loeb
Šta znači kad je "by Loeb"? :)
Ovo bi tribalo komercijalizirati:
[ame]http://www.youtube.com/watch?v=JPLh3uMw0k4[/ame]
superhrvoje
ne sviđa mi se nimalo. beskorisni "nadomjestak" nečega za papke.
baš je niškoristi auto: previsok, a nije monovolumen da ima mjesta. naravno da nije ni terenac. navodno da će i fiat uništit fiat bravo i napravit neko slično podignuto sranje.
glupa moda, isto kao sa laptopima čiji su ekrani sve manje visine u zadnje vrijeme... kod laptopa se to da opravdat time da gule kupce jer se takvih ekrana da više narezat.
al koga briga, ja i tako nisam ciljani kupac
deda
Meni su sve te linije preružne,jebeš auto kad moram pročitat na njemu ili gledat značku da bi znao koje je marke,ili to danas više nije ni važno,sve je to isti drek.
bjelivuk
NHF, ali o čemu ti?
Ovo je (zasebna) crossover klasa s jasno definiranim tržišnim segmentom.
http://en.wikipedia.org/wiki/Crossover_(automobile)
To samo znači da slabo pratiš autoindustriju. :D
deda
Ne slabo, nego nikako,jer je već postalo bez veze.Više neda neznaš kad kupiš neku marku auta,što si kupio,nego neznaš ni porjeklo odakle je i ćija je proizvodnja.Pa Croser je Mitshubishi,nema nikakve veze sa Europom,a kamoli sa Citroenom.A svi auti što su veći više su napuhani i imaju samo više plastike,a u njima mjesta ni za sendvič. Kada vidiš taj auto na cesti imaš dojam da je mrcina,a ajd negdje malo čvrkni,raspašće se ko dječje igračke i ako nemaš kasko bolje je da se kokneš.Cijela poanta je samo da te natjeraju da što više trošiš love,a da što manje imaš.Baš me zanima,ako poživim tolko, kak će ti auti izgledati za 20 i više godina,ako će ih uopće više i biti negdje osim u muzeju.
superhrvoje
NHF, ali o čemu ti?
Zašto bi bilo "HF"-ova?
To da postoji marketinško ime za takve aute ne znači da nisu beskorisni i bezveze. Mogli su ih nazvati i Šime ili Lurkex Kex, i opet bi mi bili jednako besmisleni - meni, i po mom osobnom mišljenju.
Točno kako i napisah: nisam u ciljanom "tržišnom segmentu" i ne bi mi palo na pamet kupovat takav auto. Izgleda kao svojevrsni "nadomjestak".
